Author Topic: Errors PaulsCode in Minecraft  (Read 2488 times)
Offline pierrepier5
  • bit
    • View Profile
« on: November 01, 2015, 04:51:12 AM »
Hi, In my minecraft server project, when i have launch my minecraft i gain this error:
Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
[11:42:48] [main/INFO] [LaunchWrapper]: Loading tweak class name cpw.mods.fml.common.launcher.FMLTweaker
[11:42:48] [main/INFO] [LaunchWrapper]: Using primary tweak class name cpw.mods.fml.common.launcher.FMLTweaker
[11:42:48] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.common.launcher.FMLTweaker
[11:42:48] [main/INFO] [FML]: Forge Mod Loader version 7.99.30.1492 for Minecraft 1.7.10 loading
[11:42:48] [main/INFO] [FML]: Java is Java HotSpot(TM) 64-Bit Server VM, version 1.8.0_60, running on Mac OS X:x86_64:10.11, installed at /Applications/Minecraft.app/Contents/runtime/jre-x64/1.8.0_60
[11:42:48] [main/INFO] [FML]: [AppEng] Core Init
[11:42:48] [main/WARN] [FML]: The coremod cofh.asm.LoadingPlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[11:42:48] [main/INFO] [FML]: Loading tweaker cpw.mods.fml.common.launcher.FMLTweaker from forge-1.7.10-10.13.4.1541-1.7.10-universal.jar
[11:42:48] [main/WARN] [FML]: The coremod codechicken.core.launch.DepLoader does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[11:42:48] [main/WARN] [FML]: The coremod invtweaks.forge.asm.FMLPlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[11:42:48] [main/WARN] [FML]: The coremod mrtjp.core.handler.CorePlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[11:42:48] [main/WARN] [FML]: The coremod thaumcraft.codechicken.core.launch.DepLoader does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[11:42:48] [main/INFO] [LaunchWrapper]: Loading tweak class name cpw.mods.fml.common.launcher.FMLInjectionAndSortingTweaker
[11:42:48] [main/WARN] [LaunchWrapper]: Tweak class name cpw.mods.fml.common.launcher.FMLTweaker has already been visited -- skipping
[11:42:48] [main/INFO] [LaunchWrapper]: Loading tweak class name cpw.mods.fml.common.launcher.FMLDeobfTweaker
[11:42:48] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.common.launcher.FMLInjectionAndSortingTweaker
[11:42:48] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.relauncher.CoreModManager$FMLPluginWrapper
[11:42:49] [main/INFO] [FML]: Found valid fingerprint for Minecraft Forge. Certificate fingerprint e3c3d50c7c986df74c645c0ac54639741c90a557
[11:42:49] [main/INFO] [FML]: Found valid fingerprint for Minecraft. Certificate fingerprint cd99959656f753dc28d863b46769f7f8fbaefcfc
[11:42:49] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.relauncher.CoreModManager$FMLPluginWrapper
[11:42:50] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.relauncher.CoreModManager$FMLPluginWrapper
[11:42:50] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.common.launcher.FMLDeobfTweaker
[11:42:51] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.relauncher.CoreModManager$FMLPluginWrapper
[11:42:51] [main/INFO] [LaunchWrapper]: Loading tweak class name cpw.mods.fml.common.launcher.TerminalTweaker
[11:42:51] [main/INFO] [LaunchWrapper]: Calling tweak class cpw.mods.fml.common.launcher.TerminalTweaker
[11:42:51] [main/INFO] [LaunchWrapper]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[11:42:51] [main/INFO] [AE2-CORE]: func_146977_a(Lnet/minecraft/inventory/Slot;)V - Transformed
[11:42:51] [main/INFO] [AE2-CORE]: func_146977_a_original(Lnet/minecraft/inventory/Slot;)V - New Method
[11:42:51] [main/INFO] [AE2-CORE]: func_146977_a(Lnet/minecraft/inventory/Slot;)V - Invoke Virtual
[11:42:51] [main/INFO]: Setting user: pierrepier5
[11:42:52] [main/INFO] [STDOUT]: [net.minecraft.client.main.Main:main:144]: Completely ignored arguments: [--nativeLauncherVersion, 285]
[11:42:52] [Client thread/INFO]: LWJGL Version: 2.9.1
[11:42:53] [Client thread/INFO] [STDOUT]: [cpw.mods.fml.client.SplashProgress:start:188]: ---- Minecraft Crash Report ----
// Don't be sad, have a hug! <3
Time: 01/11/15 11:42
Description: Loading screen debug info
This is just a prompt for computer specs to be printed. THIS IS NOT A ERROR
A detailed walkthrough of the error, its code path and all known details is as follows:
-- System Details --
Details:
   Minecraft Version: 1.7.10
   Operating System: Mac OS X (x86_64) version 10.11
   Java Version: 1.8.0_60, Oracle Corporation
   Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
   Memory: 68986000 bytes (65 MB) / 193081344 bytes (184 MB) up to 1060372480 bytes (1011 MB)
   JVM Flags: 5 total; -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
   AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
   IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
   FML:
   GL info: ' Vendor: 'NVIDIA Corporation' Version: '2.1 NVIDIA-10.6.42 310.42.05f01' Renderer: 'NVIDIA GeForce GT 750M OpenGL Engine'
[11:42:53] [Client thread/INFO] [MinecraftForge]: Attempting early MinecraftForge initialization
[11:42:53] [Client thread/INFO] [FML]: MinecraftForge v10.13.4.1492 Initialized
[11:42:53] [Client thread/INFO] [FML]: Replaced 183 ore recipies
[11:42:53] [Client thread/INFO] [MinecraftForge]: Completed early MinecraftForge initialization
[11:42:53] [Client thread/INFO] [FML]: [AppEng] Core Init
[11:42:53] [Client thread/INFO] [FML]: Found 0 mods from the command line. Injecting into mod discoverer
[11:42:53] [Client thread/INFO] [FML]: Searching /Users/pierre-andrebeaufort/Library/Application Support/minecraft/mods for mods
[11:42:53] [Client thread/INFO] [FML]: Also searching /Users/pierre-andrebeaufort/Library/Application Support/minecraft/mods/1.7.10 for mods
[11:42:59] [Client thread/WARN] [ForgeMicroblock]: Mod ForgeMicroblock is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 1.1.0.314
[11:42:59] [Client thread/WARN] [ForgeMultipart]: Mod ForgeMultipart is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 1.1.0.314
[11:42:59] [Client thread/WARN] [McMultipart]: Mod McMultipart is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 1.1.0.314
[11:42:59] [Client thread/INFO] [MrTJPCoreMod]: Mod MrTJPCoreMod is missing the required element 'name'. Substituting MrTJPCoreMod
[11:42:59] [Client thread/WARN] [MrTJPCoreMod]: Mod MrTJPCoreMod is missing the required element 'version' and no fallback can be found. Substituting '1.0'.
[11:42:59] [Client thread/INFO] [FML]: Forge Mod Loader has identified 54 mods to load
[11:42:59] [Client thread/INFO] [FML]: Found mod(s) [EnderIO] containing declared API package com.cricketcraft.chisel.api (owned by chisel) without associated API reference
[11:43:00] [Client thread/ERROR] [FML]: The mod TConstruct (Tinkers' Construct) requires mods [Mantle] to be available
[11:43:00] [Client thread/INFO]: Reloading ResourceManager: Default, FMLFileResourcePack:Forge Mod Loader, FMLFileResourcePack:Minecraft Forge, FMLFileResourcePack:Applied Energistics 2, FMLFileResourcePack:BiblioCraft, FMLFileResourcePack:Carpenter's Blocks, FMLFileResourcePack:Chisel 2, FMLFileResourcePack:CoFH Core, FMLFileResourcePack:Ender IO, FMLFileResourcePack:Forestry for Minecraft, FMLFileResourcePack:Inventory Tweaks, FMLFileResourcePack:Iron Chest, FMLFileResourcePack:MineFactory Reloaded, FMLFileResourcePack:MFR Compat: Applied Energistics, FMLFileResourcePack:MFR Compat: Atum, FMLFileResourcePack:MFR Compat: BackTools, FMLFileResourcePack:MFR Compat: BuildCraft, FMLFileResourcePack:MFR Compat: Chococraft, FMLFileResourcePack:MFR Compat: ExtraBiomes, FMLFileResourcePack:MFR Compat: Forestry, FMLFileResourcePack:MFR Compat: ForgeMicroblock, FMLFileResourcePack:MFR Compat: IC2, FMLFileResourcePack:MFR Compat: Mystcraft, FMLFileResourcePack:MFR Compat ProjectRed, FMLFileResourcePack:MFR Compat: Railcraft, FMLFileResourcePack:MFR Compat: Sufficient Biomes, FMLFileResourcePack:MFR Compat: Thaumcraft, FMLFileResourcePack:MFR Compat: Thermal Expansion, FMLFileResourcePack:MFR Compat: Tinkers' Construct, FMLFileResourcePack:MFR Compat: TwilightForest, FMLFileResourcePack:MFR Compat: Vanilla, FMLFileResourcePack:NEI Addons, FMLFileResourcePack:NEI Addons: Developer Tools, FMLFileResourcePack:NEI Addons: Applied Energistics 2, FMLFileResourcePack:NEI Addons: Botany, FMLFileResourcePack:NEI Addons: Forestry, FMLFileResourcePack:NEI Addons: Crafting Tables, FMLFileResourcePack:NEI Addons: Ex Nihilo, FMLFileResourcePack:NEI Integration, FMLFileResourcePack:Railcraft, FMLFileResourcePack:Tinkers' Construct, FMLFileResourcePack:Thaumcraft, FMLFileResourcePack:Thermal Dynamics, FMLFileResourcePack:Thermal Expansion, FMLFileResourcePack:Thermal Foundation, FMLFileResourcePack:TiC Tooltips, FMLFileResourcePack:Waila Harvestability, FMLFileResourcePack:Baubles, FMLFileResourcePack:Forge Microblocks, FMLFileResourcePack:Forge Multipart, FMLFileResourcePack:Minecraft Multipart Plugin, FMLFileResourcePack:MrTJPCoreMod
[11:43:00] [Client thread/WARN] [FML]: There were errors previously. Not beginning mod initialization phase
[11:43:00] [Sound Library Loader/INFO] [STDOUT]: [paulscode.sound.SoundSystemLogger:message:69]:
[11:43:00] [Sound Library Loader/INFO] [STDOUT]: [paulscode.sound.SoundSystemLogger:message:69]: Starting up SoundSystem...
[11:43:00] [Thread-7/INFO] [STDOUT]: [paulscode.sound.SoundSystemLogger:message:69]: Initializing LWJGL OpenAL
[11:43:00] [Thread-7/INFO] [STDOUT]: [paulscode.sound.SoundSystemLogger:message:69]:     (The LWJGL binding of OpenAL.  For more information, see newbielink:http://www.lwjgl.org [nonactive])
2015-11-01 11:43:00.769 java[1580:36067] 11:43:00.768 WARNING:  140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
[11:43:00] [Thread-7/INFO] [STDOUT]: [paulscode.sound.SoundSystemLogger:message:69]: OpenAL initialized.
[11:43:00] [Client thread/INFO]: Created: 16x16 textures/blocks-atlas
[11:43:00] [Client thread/INFO]: Created: 16x16 textures/items-atlas
[11:43:01] [Sound Library Loader/INFO] [STDOUT]: [paulscode.sound.SoundSystemLogger:message:69]:
[11:43:01] [Sound Library Loader/INFO]: Sound engine started
Thank You for your help, pierrepier5
